the mopar dude
Head Dude
Cast date 9-25-72, cast #2780930-340-2, left front stamping JM340R 4136. Complete fresh engine ready to install. Block tanked and jet washed, main bores checked (round & straight). Bored .040 over, finish honed with CK10 machine. Block was previously decked--checked straight. Forged crank turned .010/.010. Speed Pro L2316F+.040 with skirt coating, connecting rods resized, new ARP bolts, new pin bushings, balanced correctly (big & little end), pistons balanced +/- 0. New Melling oil pump & pickup. New oil pump drive bushing, new cam bearings. Crane H288-2 hydraulic flat tappet cam (int .458 226@050 288 adv. exh .465 230@050 292 adv. 110 lobe sep. 2600-6000 rpm range) Crane lifters, hardened push rods, adjustable rocker arms appear to be Direct Connection, "O" heads, double valve springs with dampers, all new guides, hardened exhaust seats, new stainless exhaust valves, susrfaced, valve job done with Serdi machine. All new hardware kit with timing chain slinger and hollow bolt. Double roller timing chain & gears. New harmonic balancer. Professionally machined and assembled. Test run on a no-load run stand. Complete minus carb and distributor. Has Torker 340 intake, car pan and 71-up steel valve covers, painted Hemi orange. $5800
Located in east central Kansas, can ship truck freight.
