whitepunkonnitro
This is removed from a running, driving Dart. Car drove perfectly, no leaks or issues.
Set-up consists of:
63-72 Power Steering Box with Pitman Arm
Sagnaw P/S Pump with V-8 Pulley
P/S Pump Bracket and Bolt set for Aluminum Water Pump SB
Good used High Pressure Hose with fittings
Small Spline Power Steering coupler
Power Steering column inner shaft. Your choice of 67-69 or 70-up
Shallow P/S Water Pump Pulley.
The only thing you have to add to complete this set-up is a crankshaft pulley to match your engine and some fluid!
Asking $250 plus shipping. PM me for any additional info and pics. Thanks FABO!
Set-up consists of:
