[SOLD] Complete V8 K member conversion with motor mounts.
AnotherA
Mn
I upgraded to a coil over setup and no longer have need for this stuff.
This is a complete, bolt it in and go K member setup for anyone looking to upgrade from their slant 6 or to disc brakes.
This setup already has the large upper ball joints, disc brakes, sway bar and spool type motor mounts.
No running around finding all the parts to upgrade, its all here in one package!
RUST FREE!
73 V8 K member with power steering sector.
Spool motor mounts!
Big ball joint upper A arms.
Sway bar.
Disc brakes.
New tie rod ends
New bushings in the upper A arms.
$550 or best offer.
LOCAL PICKUP ONLY
[/QUOTE]
If you were not on the upper side of the country I would snatch this up.
Your welcome! It was nice to meet you. Hope you made it home ok and got that tie rod fixed.
Same here.
Yup, parts are in hand and that's Fridays fun.
Thanks for the Mopar front end wire......;-)
Lemme know when you want to move the 15" rims/covers...I can use them once this K frame and the D60 are in.
Edited- Yes its sold. Post number 5 said so, this thread wasn't that big.
