Dragonbat13
Is it feasible to run a hot enough cam to bleed off some compression while still being able to use 3.23 gears?
If not, what is the highest (numericaly lower) gear I can consider?
I am trying ensure that I will be able to run 92 octane on 10.5 compression with iron magnum heads and .040 of quench on some forged flattops.
EDIT: The engine is a magnum 5.9, hyd roller.
