compression psi on my unknown 340.
AZ-Nick
Tucson AZ area
I finally had a chance to check the compression psi on my unknown 340.
Unknown Fairly mild cam
Cold engine
No squirt of oil
Minimum 8 rotations
Cyl:
1 167
3 172
5 165
7 167
Cyl:
2 180
4 175
6 180
8 165
What is your opinion.
Thanks
Decent. The higher numbers may have carbon buildup in the cylinders.
Looks very good to me. Fire it up and bring it operating temp. Let it cool a bit, and then do another....both dry and wet. I see no problem with those numbers however.
thanks I have the tear down in progress, I have quite a few things that I am replacing and upgrading so doing the test over is not going to happen for a while.
