FomocoReformed
Now being a relative novice to the whole forced induction scene I'm working on doing my research so I can understand everything before I finish selecting all the parts for my motor. Of course it doesn't help that this is my first from the bottom up engine build and I chose to construct a blow through carb'd turbo 408 stroker for this first project. I'm really trying to not grenade the thing and really hoping I can run it on pump gas (which my static CR is fine for, but the boosted CR... well I'll get to that)
One thing I'm trying to understand is the compression ratios I'm looking at, I've calculated it with a few different combos and it looks like I'll be running a static CR of about 8.2-8.6 depending on what I choose for a head gasket and accounting for possible variation in combustion chamber volume with my 596 heads. Here's where I run into question's I don't have answers to. Crunching the numbers on the dynamic compression ratio comes out in the mid 7s before boost and with 20lbs of boost (roughly what my turbo would be at at 3500) it appears I'm looking at 17:1 boosted CR, even plugging in 8lbs of boost it's pushing almost 13:1 boosted. Now I'm wondering in my head, is that going to prevent me from running pump gas and turn my block into a frag grenade? I know higher than 11:1 compression will make feeding it unleaded iffy but I have no idea which of these compression ratios I should be looking at for that.
Unless I'm just doing something horribly wrong in my calculations/choices. It's worth noting that I picked a cam with an intake valve closure ABDC of like 52* since I'm also not sure on what cam I should use, I know this affects the dynamic CR greatly and using a cam at 70* drops my CR @ 20lbs max to 14.
What the hell am I getting myself into... but I'm pot committed :burnout:
