Yawn. lol
Crap, I think I may have just contributed to the yawn.Yawn. lol
All the talk about compression was boring me.Crap, I think I may have just contributed to the yawn.
For 87 octane usage????????I’m asking what YOU think the benefit of running less than 9.5:1 is.
I can’t see a reason to EVER run compression that low.
Your thoughts please.
My two cents....nearly worthless... but the sooner this guy gets something going by the seat of his pants the better. I have a relatively low compression 400 with an awesome cam that will blow your sox off... I know it can be done. He needs to get on with it.All the talk about compression was boring me.
What Dan want's is something to drive with a little pep.
I think you gave a great example.
Well yea! But not for nothing… I forgot to add this in on the post…You can easily run 9.5:1 on 87.
Wow, I didn't know that there was that much difference. Thanks for pointing that out to meWhat you are missing is most factory stuff is a point or more under the advertised CR.
And you throw away way more giving up just a few percentage points of HP.
It‘s crazy to do that.
I thought that the torque was awesomeIQ52 just posted dyno figures on a mild low compression 360 less than hour ago. Looked great for a street cruiser, plenty of low end torque
That's not much of a gainIncreasing hp with compression is NOT a linear scale. As the comp ratio gets higher, there is less gain. Going from 8:1 to 9:1 is worth about 2%.
Post #41, correct, not much gain. Probably measurable on a dyno, but the butt-meter is unlikely to feel it. So if you have the parts already for a 8:1 engine, the decision becomes: is it worth spending more $$ for a one point increase in CR that might not be felt. The higher CR will help with idle quality/vacuum if you increase cam size, but then again if this is just a cruiser & the cubic inches are going to do the work, it would be fine with the lower CR & mild cam.
Very well saidDon’t buy that nonsense. As I already said, the dyno has limitations and that’s one of them.
Most of the guys spouting percentage gains from compression ratio increases get that from one (maybe more) of Vizards books. I’ve seen similar charts and graphs and they all say the same thing.
BUT…they never read the text under the chart/graph and if they did they would know that that percentage is the MINIMUM gain to be expected. Not the maximum.
If you are building something like the “Mission Impossible” engine, then I’d run bigger heads and live with the compression ratio I get.
If I’m building something that isn’t limited by rules or the constraints of some self imposed engine building flagellation then I put compression in it.
One last thing Dan. If you want to learn this stuff then you have to keep learning for the rest of your life. You should learn something every day and then apply it to validate what you’ve learned.
The learning curve is very steep, but today this information is out there from far more reliable sources than myself.
Verify everything, trust nothing until you PROVE it out.
To that end, spend some time learning about expansion ratio and how it affects engine performance. Once you get a grasp of that you will wonder why some many are willing to give up compression for old wives tales and fables.
That doesn’t mean you can build a 4200 pound car, use a 2200 converter and a 2.75 gear so you can run 95 MPH down the freeway and use 11:1 compression.
You have to apply some common sense and have a pretty decent grasp of ICE theory. But most guys can run quite a bit more compression than they do with very minor changes to the build.
As hard as this is for me to say, there is more to compression than horsepower.
Now I’m going to go throw up.
Now that that’s done, you can’t look at dyno numbers only and compression ratio. There is more to it than that and a water brake or eddy current dyno can not measure that.
Horsepower is KING, but you don’t get all the info from the dyno.
The first guy I heard who talked about those percentage increases was John Lingenfelter.Don’t buy that nonsense. As I already said, the dyno has limitations and that’s one of them.
For my goal, do I really need more than a 9.5:1 cr? I'm not going for big power, but I do want a improvement over stock.The first guy I heard who talked about those percentage increases was John Lingenfelter.
But realistically, once those cams get big enough, you're more concerned about "how" you're going to get "enough" comp in there... LOL
