Compression Stroke
carbuff
Upstate New York
Hi all. As stated in my intro, I am restoring a 1965 Dodge Dart GT with a 273 Charger engine. I know this has been discussed previously; but I am still confused. If my cam timing mark is at 6 o’clock and the crank timing mark is at 12 o’clock, is that the compression stroke? Thanks.
As post #2 says, it is but not for #1. With the dots both at the 12 o'clock position, then you are at TDC for #1.
The position you described is commonly called "dot to dot". Mderoy is correct, your are on #6 compression. For #1 compression, both dots at 12 oclock.
When the timing dots are aligned (6 o'clock & 12 o'clock) that is firing at TDC on #6.
The dots have NOTHING to do with the compression stroke ....... until you correctly install the cam.
You yourself have to positively locate the Crank to TDC#1,
Prior to installing the timing set,
that has been previously meticulously aligned dot to dot.
If the top sprocket does not fit, you have to rotate the cam until it does ........ without moving the crank sprocket.
After
this is done, you have to verify the crank is still at TDC#1, and the dots are still aligned.
After that is done, you should be able to slowly rotate the crank two full turns with no valves getting slapped by any pistons.
But you really don't know if any marks are accurate.
To sleep better, I would still figure out where "split-overlap" is occurring, relative to #1 TDC. Split overlap is when both valves for a given cylinder are open the same amount. The window for this to occur is about 4* retarded to maybe 8* advanced, and you want to be somewhere close to, in the middle of that.
On an SBM with hydraulic lifters, this can be a tall order, and
if you don't do it, it's no big deal; if the sprockets are accurately marked.
Before you put the distributor back in, make sure #1 cylinder is at TDC compression. Then back the crank up to say 10 * advanced, then stab the D in with the rotor ending up under the #1 Tower, and continue.
Good luck.
Thanks for the info. I did measure TDC #1 with timing marks lined up, then I rotated two crank rotations to get two compression stroke. Then I stepped thru every 90 deg and created a cold lash at the correct valves. I admit I didn’t meticulously look at “split-overlap”; but have rotated it a couple times with no valves hitting. I will take into account your 10* advanced position before installing distributor.
To make it easier than a convoluted bunch of boosheet, put a degree wheel on it.
Sorry, meant to say I rotated crank one turn from “split-overlay” to get to compression stroke.
I wasn't talkin about you. I was talkin about the clear as mud BS in post #7.
If you're there, degree wheel it. Those marks are for assembly line people. Unless you're getting a paycheck to assemble it as quickly as possible, degree wheel and verify.
Per the service manual, the slot in the distributor drive gear should point to the #1 intake bolt. That is not the case on my engine. I don’t know the history of the crank and crank gear; but so what if you line the rotor up with what I establish as the #1 contact. The service manual says to actually rotate the distributor counterclockwise until the rotor and contact are starting to seperate.
So the last you responded before yesterday was September 12th and you STILL don't have this figured out?
unless it's a factory restoration then you don't 'need' to have the rotor pointing to anything in particular. as long as when you are running the plug wires you connect number 1 lead to the point on the cap that the rotor is pointing at you'll be fine.
i'm waiting to be shot down in flames now, lol. :poke::lol:
neil.
Where the rotor points for #1 spark plug is really just for identification by dealer technicians etc for easy ID.
And the factory cut wires probably routed nicer .
I was perplexed by the dot to dot thing as well when I first started building engines . Now I use a degree wheel .
