67Dart273
So how do you get the company to send you the backup disc,
will they send them if you ask or must you buy?
Depends on the company, and "times change."
Just a few years ago, a guy I was tutoring to get his amateur radio license had the typical load 'o crap, had punched every button that says "you need this" and downloaded every stupid doo dad that people emailed him, until it would barely run
It was still under (extended) warranty. I called Dell, fed 'em all the answers they wanted, and here comes a package of about 6 CD/ DVDs, for Winhosed, burner software, the works, whatever was on the machine.
In the "good old days" you could actually buy a machine that CAME with backup
Now don't get me wrong---most? all? machines have a "run it once" program in the machine that will burn you backup disks, BUT these are "home burned" and I really don't trust 'em. I want FACTORY disks.
All it takes is ONE machine, NO disks, and there you sit, a dead hard drive..................
Now there IS other ways around this in SOME cases
If you can scare up the proper edition of Winhozed fer cheap, IE borrow a friends and burn a copy, you can reload Windoze with the product key on the machine, BUT
The last two desktops I've had were PAPER stickers on the bottom of the machine and became unreadable in short order, so you want to be sure and write down the product key, like on a sticker on the top of the keyboard
And to pull off th above, you must have the "just right" version of Winhored. You cannot use a "retail" or an "upgrade" version with an "OEM" product key, and it matters whether it's home, pro, whatever.
AND that doesn't take care of your office, photo, other software that may have come with the machine originally.
SO, we're back where we started -- you want factory backup disks for your machine.
