Word to the wise.......not sure if you are asking this question because you are in the middle of assembling a fresh engine or not? but if so....while you are in the area,do not forget to prime your engine.
Thanks guys. my engine builder and i did put 4 qts of oil in and spun the oil pump with a electric drill to see if there was oil pressure which there was and he primed the engine. I just didn't know how the the distributor hooked up since the oil pump shaft was taken out.
