black954
So i've been working more on my Dart lately and i've hit a big snag. I planned to make my own serpentine brackets and reuse the Dakota RT alternator, water pump, and power steering pump. Unfortunately, I cut up the original brackets to mount everything and now i'm left trying to figure out the best, most economical accessory drive. I can't reuse the Dakota RT PS pump because it is a low pressure pump for rack and pinion. So now i'm looking at piecing together a system. I have the original 340 front cover so I guess I could go that route and run LA accessories, but with the RPM i'm turning I will not run a V-belt system. I was hoping to reuse the magnum balancer I have and if possible the magnum alternator. PLEASE HELP!
