Thank you! So I don’t see the brake booster tying into the carb at all. It looks like the setup has an electric vacuum pump for supplying vacuum to a power brake booster.You should connect it to the spot that has a hose with a bolt in it. That goes into the carb spacer so there is no nonsense going on with it.
Where does the brake booster plug in? Don't put the PCV on the same connection as that and don't put either of those on a runner directed to a single intake port.
If you have a vacuum pump you don't need to hook the booster to the intake.Thank you! So I don’t see the brake booster tying into the carb at all. It looks like the setup has an electric vacuum pump for supplying vacuum to a power brake booster.
Should there also be a hose connecting to the carb for the booster?
No, leave that like it isShould there also be a hose connecting to the carb for the booster?
My vote is to take out the hose and bolt. It will look more sanitary with the cap on the other vacuum source.
IMO, one valve cover should have a straight breather connected to the air cleaner and the other PCV connected to the carb base(blocking bolt). Clean air goes in one side of the engine and the PCV evacuates air/fuel/oil mixture out into the carb base to be mixed with the air/fuel mixture there to be burned cleanly.So both valve covers had breathers. When I’d drive the car those breathers would smoke a little after the engine heated up and without fail leave the tiniest coating of oil on everything. The engine has less than a few hundred miles on its So it was suggested to me to added PCV to the passenger side valve cover and hook it up. I bought the below one from spectre so we’ll see how it does:
I like the air pump for the booster. It keeps the air/fuel mixture out of the booster and relies on a constant 12V instead of engine vacuum.
I wouldn't worry about that. (unless New York requires it) You have a breather on one cover and the pcv hooked to the base of the carb on the other cover. That should be all you need.So I have a breather with a nipple on it that I could use on the other valve cover but I’m not seeing a spot to hook it up to the air cleaner. Is that something I’ll need to make myself?
