ProComp city. lol
Some times you get lucky and some one is selling what you are looking for. I'm with you, I can't stand cheap tools.
ProComp city. lol
I used to wrap a rag around the rubber slip grip of the turning lever/pipe on the engine stand....I'd put the rod big end over the end with the nuts loosened to last 5 threads and then use a hard plastic head hammer to tap each bolt on the nut while slight pulling down on the rod till it separated. I did that for 5 engines before I got sick of it...lolI build enough engines to justify one. This last set of slant 6 rods I had resized were TOUGH to separate. I cannot STAND hitting on remanned rods with a hammer.
I'd do all 8 at once and then lay them out with their caps for bearings to go in etc...
The vise idea came about and that was end of hammers.
Removing a few fingers make it hard to hold a beer,what about something like this?
Tail Pipe Tube Exhaust Muffler Expander Spreader Tool Kit Set 1-1/18" 3-1/2" | eBay
you would want to remove a few fingers so it only presses up and down, not sideways (if that makes sense)
thats why they make theseRemoving a few fingers make it hard to hold a beer,
