dibbons
Got the heads off the .040 over 340 I purchased. Before removing the rotating assembly, I wanted to make sure the connecting rods and caps were marked. Can't find any numbers imprinted on them, so I purchased a little number set at Ace Hardware. My question is this: it looks like the flat area where I plan on staking the numbers has some kind of squirt hole right there. Are these squirt holes installed correctly? I don't remember seeing them there in my past small block rebuilds. Thank you.
