Console location 72 Duster
DueceDuster
Summerfield, Florida
I am putting in a console in my Duster. I have to weld in the mounting bracket. Does anyone have measurements for the bracket or the console placement?
I also need to mount the new bucket seats, what are the measurements for placement of the new inner mounting holes?
I assume the reinforcement plate for the inner mounting holes weld to the under side of the floor. Any help appreciated. Thanks.
added plates for buckets go inside not under the car. Factory floor pan has dimples stamped where the 4 holes would be drilled. You'll need 4 rubber plugs where a bench was mounted.
I assumed the bucket seat tracks would use the same outside holes as the bench. Good to know it doesn't. So look for the dimples, thanks.
Just finished this up myself where the PO had drilled about 15 holes for some crappy seTs out of a foriegn car
