Nah, then you'll be way faster than me lol.I think I need to step up and just get some crazy ported Victor heads with a matched Super Victor intake and a Dominator.... lol
Oh **** I said typed that
Uh Bill, there's these things called tunnel rams.I think I need to step up and just get some crazy ported Victor heads with a matched Super Victor intake and a Dominator.... lol
And we have a winner! @jimjimjimmy got it on the money with his guess of 429!
Not quite what I was hoping for but it’s a good baseline to work off of and it will only get better.
Jim, message me your t-shirt size and address and I’ll get your prize shipped ASAP!
haha, trying to decide who to go with between Indy and Victor....both seem good but my wife said I could only pick one.I know this length of time without a reply from Bill, he's ordering new **** already
Either is good, look for future potential !haha, trying to decide who to go with between Indy and Victor....both seem like cool dudes but my wife said I could only pick one.
Honestly, I don't think I will do anything until after I get the car to the track. See what it will do and then go from there.
My wife doesn't know either....lolEither is good, look for future potential !
My wife doesn't know, lol
Haha, excellent!!!My wife doesn't know either....lol
All of it. That's my dream engine!
I had IMM freshen some pro-ported 286 max heads I have.Yeah I believe the sm 325 is the actual max wedge port. Tf 270 is off be quite a bit.
That would be a cool comparison.I had IMM freshen some pro-ported 286 max heads I have.
I should have had Brian flow em and cc em. Oops. Oh well! Would have been an interesting comparison to tf 270s and sm cnc victors.
With the screen name "boosted" I am wondering if this is a serious question?, you already said you have nitrous!. Mid-low ten second bracket car and hit the juice on grudge night.Now to decide if I play with what I got or build a big block.
So far this is what we have experienced with the two trickflow headed 408s that went across the dyno. One made 527hp/525tq and mine went 550hp/550tq, for referrence a a third 408 had cnc speedmasters and made right at 500hp. All three of these engines started out at or below 500hp with two having custom carbs and they all picked up quite a bit with a timing curve/carb work. None of them were full tilt builds with compression ratios from 9.8, 11.1 and 10.4 and solid flat tappets between high 240s to high 250s with mid to high .500s on lift.I’ve seen guys claim 530-560 hp from trick flow heads on 408 cubes, either out of the box or ported. If you factor 20% drivetrain loss this package is right about where it should be imo, right about 535hp. I don’t think the camshaft is the limiting factor here. I think you’re running out of cylinder head. And it shouldn’t be shocking at all that a nice radius entry at the top of the carb is better than a sharp shear edge. The filter just ends up not being that much restriction.
I am half tempted to pull the engine out and throw it on a dyno to see what kind of numbers it would make at the crank. I typically don't really care much about dyno results but I keep hearing about others making more with less and so it has me thinking....So far this is what we have experienced with the two trickflow headed 408s that went across the dyno. One made 527hp/525tq and mine went 550hp/550tq, for referrence a a third 408 had cnc speedmasters and made right at 500hp. All three of these engines started out at or below 500hp with two having custom carbs and they all picked up quite a bit with a timing curve/carb work. None of them were full tilt builds with compression ratios from 9.8, 11.1 and 10.4 and solid flat tappets between high 240s to high 250s with mid to high .500s on lift.
I agree, get it down the track and see what it does before making any more changes, I am guilty of that a lot.I am half tempted to pull the engine out and throw it on a dyno to see what kind of numbers it would make at the crank. I typically don't really care much about dyno results but I keep hearing about others making more with less and so it has me thinking....
I bracket race so getting the car to be as consistent as possible is more important than anything else so I will wait for the tracks to open up and see if I am happy with the combo. If not, we will see what is next but throwing a 100-150 shot at it is always an option. lol
Wait, I thought you said you were happy with it?I think I need to step up and just get some crazy ported Victor heads with a matched Super Victor intake and a Dominator.... lol
hello. you will easily be running over 600hp
taking in the percentage loss to the ground
552hp respectively
all the best. very nice set up
lol, I'm just messin with @MOPARMAGA. We are planning on running heads up against each other this coming summer. Gotta try and get in his head since he's gotta few more cubes and a whole lotta HP's over me.Wait, I thought you said you were happy with it?
Yeah, I'm not going to put the Victor heads I ordered (a while back and still on back order) on my stock block. I'll save them for a 48 degree (lifter bore) race block if I can ever get my hands on one. lolJust a reminder. A couple of us are leaning on these stock block 360’s pretty hard running 5.80’s-6.0’s. There’s a line in the sand that we are pushing pretty hard. There is a breaking point. Most of us in that area are bracket racers out racing not test n tuners making a few hit when the weather gets nice. With Indy heads and especially Victor heads I guarantee you the breaking point could be hit. Notice I said could. I know I’m giving up a .020-.030 by not running a 10 inch radial tire, and a toilet system, and racing at one of the “super tracks” so the question is how hard do you want to push it.
