Converting 71 standard dash to rallye
des69mopar
Are the fan/heater controls different? Can l use my controls from my standard dash? Is there a special mounting bracket?
You might have to change the whole dash frame to make it all work.
I changed the dash frame, have a rally bezel, cluster, harness, using my ashtray from my standard dash, can I use the heat controls from my standard dash or are the specific to a rally dash?
They are not all the same. 67 controller mounts to 67 standard and rally. 68 and later mount to standard and rally. If you have a 67 rally instrument housing, the later climate controller will not bolt up.
