The Demon doesn't look that bad. The door striker is normal, from a loose door hinge, and an easy fix. I would check the floors under the rubber mat, and check the quarters real good. If the floors are bad you should be able to see them from under the car. The 72 looks to be a fairly good car. I would bet that $7000 cash on the hood of the 73 duster buys it.
