To convert from solid lifter setup to hydraulic setup on a slant six requires, ALL of these items.
Cam
Lifters
Pushrods
Rocker arms
If using used rocker arms, they should be kept on the shaft they were run on.
The rear rocker arm shaft bolt, should stay with the head, as there were some changes, in size, depending on year
