Divenut
Hi Folks,
Was out in the garage fiddling with the Duster and noticed a puddle of coolant sitting on the flat above the water pump. (See the red fluid on the pics below) Car's been sitting for almost 2 months and was not leaking when we last drove it. Guessing either a bad front (cork) gasket on the intake manifold or that short hose going from the pump to motor. Sound like the most likely suspects? The coolant system was pressurized and virtually full when I popped the radiator cap. No evidence of any coolant anywhere else on/under the car. But seems odd that it would leak while just sitting in the garage.
Thanks much,
Pat
Thanks much,
Pat
