TRASH
Active Member
I finally got my Duster fired for the first time and have to order tires now so I can drive it. The fronts are already taken care of but I still need rears.
I have a set of 15x7 Cop Car steel wheels that I will be using till I can afford two new rear wheels. I have not moved the rear leafs in so everything is where it was when it came from the factory. I was thinking 245/60R15's would fit and look pretty good but would also like to have as much tire as possible without stuff rubbing.
Any suggestions or oppinions would be great.
Cheers, Steve.
Cheers, Steve.
