Just throwing it out there for ***** and giggles.
When I ported my head I just barely went to clean up the edges of the combustion chambers especially the jagged edge around the intake valves, and I set a HG on the head and it seems I should have left it alone, as now the chamber edge won't cover the fire ring on a stock style replacement HG. I'm probably less than 1/4 of the way into the fire ring, but that sliver that sticks out past the chamber bugs me, even though it's plenty big enough to clear the edges of the cylinder bore. I came up with an Aussie HG from a buddy of mine from the slant 6 site and when I asked "how much" he said "just get me another one, don't have to be in a hurry" well, if I can convince myself that a stock replacement will be fine, or possibly get me a copper one I can give this one back.
I'm looking at daily driver just under 9:1 so I know that considering that copper would be unnecessary, but just thought I'd ask about the idea anyway
While we are on the subject just like the brass freeze plugs idea, the copper should be more corrosion resistant by the water jackets as well, right?
How thick are typical copper head gaskets for a slant? This isn't something that I plan to tear apart very often once assembled and running. One reason I don't want to run the Aussie one is the extra thickness. Between the head and block I have had 100 thou shaved. 30 off the block and 70 off the head. I'm thinking that I should have reversed those numbers but what's done is done and that's how it's gonna be. And another story, besides
