Copper or Aluminum bearings
chryslerfat
Monroe,Michigan
Which is recommended for a stock build with factory low compression. It will be run in a demolition derby car and see times of overheat without coolant.
well not Babbitt top fuel type
IDK about "copper" do you mean the three layer premium type?
actually any would work- it's the oil you want cool
hint
STP is the racers edge
can you hide water injection? (LIKE from the window washer)
Yes I meant the 3 layer.
No we are not able to hide water injection.
I found last year it gets so hot that it will melt a nylon oil line for a gauge. That was the 1st and last time I run an oil gauge.
I ran a temp gauge last year and she got up to 280.
