[SOLD] CORE 5.9 motor
DionR
Spokane, WA
For Sale: 5.9 motor complete - CORE
Shipping from: Not an option
Price: $50 OBO
Payment Methods Accepted: Cash or Money Order
'98-ish OBD2 5.9 motor, oil pan to TB but missing FEAD, distributor and some fasteners.
This is a CORE motor. Looks like #8 injector was leaking and that cylinder has a ridge so it will need to be bored.
Also the PS head had an exhaust manifold bolt broken off in it and I (unsuccessfully) tried to remove it.
Good source for a block/crank/rods, plus valvetrain parts, injectors, etc.
Much cheaper than the local Pull and Save and no need to spend an afternoon pulling it.
Local sales only. Willing to deliver in a reasonable distance.
Engine dolly is NOT included. Engine only.
I have another cam I can sell if that's all you need. Seems like it has some rough lobes so don't know if you can use it?
Just need a 5.9 cam for a regrind, so if the rough lobes aren’t completely wiped it should work, thanks. I’ll PM you.
I should add that the pan has a hole and a rubber plug in it, that's how the yard it came out of drains the oil. So the pan is really only good to keep the drips down.
I forgot about that when I posted it and I can't modify the original listing.
