LovetheA's
I have another question for the gurus. I had asked a question before about the bad wheel hop in my 67 gts 4 speed. I had to have the driveshaft replaced after a mishap and the mechanic was incompetant to say the least. If the drive shaft wasn't a correct replacement could that offset the pinion angle and cause the wheel hop? What is the correct drive shaft length and what are the measuring points?
P.S. I recently purchased the MOPAR chassis and suspension book ninth edition. That book is a wealth of info. Thanks for the heads up.
Carl
Carl
