63SplitWindow
I'm working on an H code 73 Dart sport that is extremely clean and appears to be correct low mileage car (59k). The original 340 motor is gone and replaced with another small block. While in the process of installing TTI headers, I have come across an issue with the location of the motor in the body. TTI says the small blocks need a minimum of 5 1/4" space from the center of the crankshaft bolt to the top of the K member for the header to make all clearances. I'm more than 1/2" short of that. I have the spool type motor mounts which I am skeptical about holding down a potent small block. Is that correct for a 73 small block?
