So the Melling 72-S2 would work here?A stock pickup. Just make sure when you install the pick up that it LIGHTLY touches the bottom of the pan.
Do not adjust the pick up so it’s not on the floor of the pan.
Car but the engine is from a lite truck I believe.Is this a pickup truck or a car ?
so you are putting a car pan and pickup on the engine.Car but the engine is from a lite truck I believe.
1974 PLYMOUTH DUSTER Melling 72-S2 Melling Oil Pump Screen Assemblies | Summit Racing
car will be center sump. Truck will be rear sump. AND.... you have to have a 360 pan for a 360. 273, 318 or 340 car pan will not work.What are the tell tale differences between a car and truck pan? Will double check to see what I have.
