kiss
I have a transmission cooler, not using the radiator, for my 727 transmission. I have a question on how to hook it up. The cooler is mounted so that the ports are on the driver's side. The cooler is bi-directional so it doesn't matter which way it's hooked up, but I wanted to check on something.
Should the outlet from the transmission (front line) be connected to the bottom or top port on the cooler? I thought I read somewhere that people said bottom port so the fluid doesn't drain back to the transmission after shutoff? Is this true?
Thanks...
Thanks...
