Corrosion resistant paint
1BadDodge71
FABO Rice Hater
Fort Collins,Colorado
Ive looked and tried alot of things for the battery tray and still corrodes like a sumbitch.Anyone know what I can use for the battery tray and holder that is corrosion resistant?
Sandblast it till its clean (gray in color) No rust what so ever or buy a new AMD one. Epoxy prime it and paint it. I never had one go bad.
thinks everyone.Ill try the POR-15,heard its good stuff
@Nuttyprof
It was sprayed with Rhino Liner stuff,still corroded
@440
It is (was) new,and it corroded,even after epoxy and Rhino Liner
Ill sand blast it and try the POR-15
I coated the one on Billy's old '64 Ford tractor several years ago and it's holding up nicely. Gets some flaky white residue on it sometimes but it washes off.
@Nuttyprof
@440
Make sure you do it as per POR instructions. They recommened using thier self etch. I had luck with POR and I also didnt have luck with it. And for the price I believe thier are better products out there.
