pacuda59
pacuda59
Is there anything to spray inside a light socket to retard the corrosion? Had a hell of a time removing the brake/blinker light yesterday.
Dab some bulb grease on the bulb’s metal case and it’s bottom terminal contact and the bulb will be a breeze to remove in the future. You could find bulb grease in just about any automotive parts store as well as Walmart and Amazon.Is there anything to spray inside a light socket to retard the corrosion? Had a hell of a time removing the brake/blinker light yesterday.
