Could someone post a pic of hard fuel line routing?
Muswagon
Winnipeg
My Duster had a mickey mouse line run, which is now gone. I need an idea of where to route the hard line from near the tank to near the pump.
I have run lines in the past, but the Duster has some strange orientations of subframe and areas to run the line...or i am an idiot...or a combo...
Any pics would be appreciated thanks!
I have some from a 69 Dart if you think that will help. Not sure how that would translate to a Duster though. Let me know if you want them and I'll dig them out.
Not sure what year or engine your Duster is.
Snapped a few quick pics from the ground of my 69 Dart big block.
(I can't get it outside or up on a lift right now, but can move it for more pics if halfafish can't).
1) Feeds from hard line to mechanical fuel pump right side.
2) Can't get to right side under engine right now.
3) Runs along right side frame.
4) Turns up into tank area just in front of rear housing bushing on top of frame. 2 pics.
5) Pic of turn taken from ground looking up.
That is exactly what i needed! Thank you
Please be sure to enclude what year what modifications in future posts.
You know what you are working on but we don't.
The thumbnail picture of your car looks good. Post a few more pics, please.
Latest pic, its dirty and my garage is a mess
Oh Lordy, dude. You have no idea what a mess is. Your shop is a pristine operating theater compared to mine. I have to slither sideways all over to access areas of the shop. If I put on five more pounds I won't fit at all. I should go get you some photos but I'm not sure I can do so and survive.
Here is what I have on the fuel line. It's a 69 Dart, 340. I got the lines from In Line Tube. Between what I have and what @Joey4speed posted, you should have a good idea how to route your line. I did fab up another smaller line for vapor return. I did that one by hand, copying the In Line bends more-or-less, to get it back to the tank.
Here is a shot of the tank area.
From there it goes to the passenger side, where it makes a square bend around the rear frame rail. It then follows the inner seam of the rocker.
It goes forward to where the front seats are bolted up (you can see my seat studs) and goes inboard about a foot where it wiggles up to the t-bar crossmember. It goes through there, and then up to the fuel pump.
Hopefully this helps on your Duster.
