This is a paste and copy from another post, but I added to it as well.
DGC333, Anyone else whom knows. Once the pin is out, the coupler should seperate. Correct?
(That is slide off the or away from the main unit/stud that it is on.)
That's where the "rust" will be a "Bear?" (As in rust on the shaft exposed and inside?) Below, is where I'm at now. It will not come apart. Not easy at least. I don't want to force it. I'm wonder if I need to get tuff on it. I'd hate to purchase a new parts because I broke it. Never did this before.
(Now wheres that tuff guy hat I used to have? He he he.)
That "Roll Pin" was a red plastic peice. It is out now.
