Confusedcuda
I have the CPP drum to front disc conversion kit I got from Classic ind. (their part#MN5004, CPP# A6374CBK-S) I noticed when I got the kit it came with some extra banjo bolts, sizes all seemed a little different. I have installed and when I went to bleed them, it seems I'm getting air around where the brake line and the banjo bolt and caliper meet. My rear set seems fine. Anybody have any idea what size of banjo bolt is SUPPOSED to be in these front calipers? CPP has you leave a short message and your phone# at their tech line. We will see. I have both washers installed, thanks.
