cppa headers
I have a brand new set of a body CPPA 1 3/4" under chassis, nickle chrome type finish, new never installed that I bought new in the early 90's
and never used. The are just hangin on the wall looking real good. Would take $500 plus shipping from Toronto, ON Canada. Might have instructions but no hardware.
I found a set of new ones on Ebay a few years back that the guy didn't know what they were and picked them up for 50.00. After I had test fit them on my 69 with P/S and found they fit I had them jet coated and wound up with 225.00 in them. They fit great and don't leak.
The ones I have hit both valve covers,the starter,right inner fender,both torsion bars,right collector flange 2 inches off the ground etc.I still have them hanging on the wall as a reminder of how bad I got screwed.
Mine fit great, other than I had to use a full size starter which is a pain to install. If i need to replace it in the future, I'll buy a clockable mini starter. But they clear everywhere, not by much but they do clear.
You could not bolt a full size starter on period with the set I have.The valve covers could not be removed when the headers were bolted up.A good friend of mine had a set of 2 inch(maybe 1 7/8 can't remeber)tube cppa that fit like a glove.My 1 3/4 not so much.
are these for a big block if so is each tube separate.... Artie
My CPPA headers have each pipe separate but not separateable.
All pipes welded to collectors and to the 1 piece header flange. They look pretty much like the TTI. I understood the earliest ones had one pipe detachable that ran on the outside of the frame rail. (had to make an opening in the inner fender.)
