66Dvert
Working on my custom car parts again!
I'm looking for a few different years 63 (if they had a dash pad) through 65 dart and valiant dash pads. I don't want good ones just need the old cracked crazed ones to strip to metal and check against my good one to build new vacuum forming molds and foam pouring mold. just to see how hard it will be to built up pouring dense foam over it in a mold and vacuforming vinyl(as soon as I can locate some non backed vinyl to test, the 4 way stretch backed vinyl worked okay but not perfect) on that new substrate. they will not be "Exactly" like the originals since I'm using vacu formed .125 ABS with glued in studs to mimic the metal substructure the original had.
so far most dash pads(externally) look just like my 66's do and it would be nice if that were true internally.
I'm looking into the process of remaking an aftermarket dash pad for a 66 dart for sure (stock) and with a 3 pod turbo mod (mine) and other years if they'll have minor mods needed to adapt.
pm me with pic's and price
thanks
thanks
