Yeah, those look like they take the shank nuts. I bought the ones that take the acorn style lug nuts.
You guys read the wheel description? Shank style lug nuts, Shank Length .767 Shank Diameter .592
But the wheels the op bought take a very special shanked lug, not conicals. Says so in the description of the wheels he bought.I bought these with the conical seat lug nuts.
Cragar 61C5654: 61C S/S Direct Drill Chrome Wheel Size: 15" x 6" - JEGS High Performance
The 9004's are left handFWIW, OP needs to know what works so he doesn't buy the wrong lugs when sourcing.
My stash includes shorter lugs, 5/8" shank I believe, that were the standard issue back in the '70s. Three of these even have a lead on them. They were notorious for loosening up.
IMO, the 9004s (long shank in picture) aren't all that much better either. The washer face on the lugs is too small and deforms the washers over time........
Now if the OP must have 9005s, is he SOL on such as 9004s above?
If we know what the difference is (or is not) maybe the OP can use 9004s and it open up options. The only thing I see "special" between the two in Summit's description is the same alert for the wheel in the bottom line........
Problem is you can’t get either one. They are all on boats.If you are desperate, you could get some stock mag shank lugs, and turn down the o.d. of the shank, on a lathe. Ive done it. You would need anti-sieze on the now naked shanks.
Unfortunately no, the shank diameter is too big.Would this set work?...........seems only thing different is the washer.
Going through same thing myself right now.
Cragar 27721-4 Cragar Wheel Lug Nuts | Summit Racing
Same problem, shank diameter is too big. I ordered the correct ones from Summit on back order. They say January but I'm not holding my breath. Good news is I'm still doing body and paint anyway so I'm in no hurry other than to see what they look like on the car.I like McGards. Many are still American made. All those I've used on many cars in the last 30 years have held up very well. Cragar nuts always got rusty on me.
McGard 61001 McGard Lug Nuts | Summit Racing
Looks like you'll have time then. I saw the difference, but thought .087" difference might work in a used wheel. If you get stuck, you could hone the wheel with some coarse sandpaper, and use the nut with the slightly larger shank.Same problem, shank diameter is too big. I ordered the correct ones from Summit on back order. They say January but I'm not holding my breath. Good news is I'm still doing body and paint anyway so I'm in no hurry other than to see what they look like on the car.
Yeah I could make em work, but like I said, no hurry.Looks like you'll have time then. I saw the difference, but thought .087" difference might work in a used wheel. If you get stuck, you could hone the wheel with some coarse sandpaper, and use the nut with the slightly larger shank.
They got a few that are close but not exact
