greymouser7
Vagrant Vagabond “Veni Vidi Vici”
- Joined
- Apr 17, 2010
- Messages
- 3,729
- Reaction score
- 1,457
http://charlotte.craigslist.org/pts/4783030639.html
NOS Mopar Saginaw Power Steering Pump Dodge Plymouth 1970s - $35 (OBO) Salisbury)
NOS in box Saginaw power steering pump for mid to late 70s Dodge and Plymouth. Mopar part no. 4115470. Appears to fit 360 and 440 engines. Do your research for correct fit. If the reservoir outlets are not configured correct you can probably swap your old one onto it. Cash sale make offer. email or text call 7zero4-2six7-644three.
http://hickory.craigslist.org/pts/4731387248.html
Up for sale is a set of aluminum Zeus Mopar Dodge heads. These may not be matching and I don't know much about them other than one of the heads is for sale on summit racing for $1600.00. All i want for both is $800.00 or best offer. If interested call my cell at 201-602-1666, my name is Dean. The ad will run until the parts are sold.
http://charlotte.craigslist.org/pts/4756215291.html
new auminum mopar performance valve covers for magnum - $100
brand new mopar performance valve covers in box with caps 100.00 valve covers fit 94 and up 318-360
Mopar 360 Engine. 1970's. - $325 (Five Forks)
http://greenville.craigslist.org/pts/4795033621.html
Mopar 360 Engine. 1970's. $325 (Greenville SC- Five Forks)
1977 SB 360 unmolested numbers matching 4 barrel engine. 78,000 miles on engine. Complete engine except carb and distributor Including pulleys, brackets, intake, exhaust manifolds, etc.. I pulled intake and one head for inspection before listing it. No ring grove. Cylinders might be able to be just honed but probably need to be board 10 to 20 thousandths. Heads look Good. Will work a trade for a good set of SB 915 J heads or two like new 15" or 17" Cragar s/s 4.5 bolt circle rims. No other trades considered. 864-449-0443.
Cast numbers:
Engine- 4006830-360
Heads- 4027596
Dual plane intake- 4095080
http://minneapolis.craigslist.org/hnp/pts/4793762954.html
Up for sale is a nice restorable Grille from an A-Body Mopar. This will fit 1970 and 1971 Dodge Darts. All the cracks have been cemented and the grille is now resdy for minor filling, sanding, and paint. These grills are getting harder to find. It is in decent shape, but definitely needs work
http://tricities.craigslist.org/pts/4799643392.html
1970 Mopar 340 Block "Fresh from Machine Shop" Rare Find - $1200 (Jonesborough, Tn)
I have a 1970 Dodge Demon 340 Block. 0.30 over with cam bearings and brass freeze plugs. Just came back from machine shop 2 weeks ago. This is a rare and hard to find block especially being 1970. All work has been done and ready to be assembled. "This is block only"
Thanks, Derek
423-440-0019
http://charlotte.craigslist.org/pts/4795290073.html
4 MAGNUM WHEELS FIT MOPAR, MUSTANG,AMC,SAND BLASTED, AND POWDER COATED SILVER AND BLACK,NEW CENTER CAPS, NEW CROME LUGS, 4 NEW WHITE LETTER TIRES 215-7RX14 WHEEL CAME OFF A 1964 CHRYSLER 300 TIRES ARE FIRESTONE PRIMEWELL SPORT P5860 LESS THEN 100MILES call 704 698 0223
Cast numbers:
Engine- 4006830-360
Heads- 4027596
Thanks, Derek
423-440-0019
