[SOLD] Crane Blazer hyd 288-2h 340 cam
bbrroowwnn
never re member
Drums, PA
used Crane Blazer hydraulic cam out of 340 that was running.....288-2h is the grind number.....Specs 218/230 dur @.050 with 488/498 lift for 25.00 + shipping
dont scrap it yet! Let me tell a guy I know...
These are some specs on the same cam from another site: Maybe the same?
H-288-2 288/296 226/234@.050 .458/.473 lift 114CL 109
I have the lifters but they were not kept in order so you would have to install new lifters
Is it too much cam for a 273 commando street only build ? Create enough vacuum for power brakes ? Sorry but I know zilch about bump sticks.
•Camshaft, Hydraulic Flat Tappet, Advertised Duration 260/268, Lift .430/.450, lobe separation 110 degrees, Duration at 050 inch Lift 221 int./228 exh.
Chrysler, 273, 318, 340, 360
These are the specs for a recommended cam in earlier thread.
Some are the same , lift is a bit different.
