I use it on my dart street/strip car.
Its a big block though.... anyway You go from valve cover to header collector with a hose. jegs sells the evacuation kit and its a weld on kit.
Works great for me although my headers already had it like it was used at one time already, I had evacuation problems with a pcv valve where I had alot of pressure build up and thats why I went to evacuation.
The exhaust going through the headers creats a vacuum and pulls gas out of the motor, you can actually feel it if its disconnected from the valve cover.
Works better at higher rpm's as mentioned because its going off exhuast.
Being that smallblocks as far as I know are more high rpm motors I would use this system....
Any questions let me know
