lhearold
You can use the 273 forged crank and depending on what pistons you choose may be real close on baslance. Ther is plenty of area on the counter weights to add mallory metal to balance if needed. Just be sure that you choose a good machine shop. As for using a 360 crank, I did that years ago but you will need to turn down the main bearing area to the 273/318/340 size and then internally balance with mallory metal. If I remember right the machine shop I used actually had to remove a little from the counter weights during the balance but then again I was using a 318 block.
Larry
Larry
