rod7515
Im going to need to do some crimping when I start on my wiring. I'll be moving the battery to the trunk and the positive wire that came with the kit is 1 gauge per markings on the wire. My question is the crimper I am looking at which is an ebay inexpensive one (yes cheap version) says it will crimp 1/0 gauge along with 2, 4, 6, 8 and 10 gauge wire. It has an adjustable die setting. Is 1/0 going to be the same as 1 gauge or will this not work for what I want to do? Heres the link to what Im looking at. Keep in mind I will only be using it for a one time use! Thanks
Rod
<img src="http://i.ebayimg.com/images/g/XIEAAOSwk5FUtyOU/s-l500.jpg" alt="HEAVY-DUTY-HEX-CRIMPER-CRIMPING-WIRE-LUGS-TERMINALS-10-GAUGE-TO-1-0-GAUGE-TOOL"/>
Rod
