Knuckle, first, the price is high, I agree with 1700 - 2000 for everything with a few considerations: Your dads 67 GTX, if this is a correct motor, then the heads will be 915's, check the casting numbers, these are a one year only and came factory on the 67 GTX's, not hard to find but are spendy if you are going for a restoration.
The block, if it is a 67 Block will not have the ribs down the side, last/first year of the 440 with no ribs, again PITA to find for a resto.
The water pump is the wrong year, but on the bright side, if you have all these parts, they will fit in to one of the 67's without issue. Depends on what you are looking for. And the headers will be a good purchase with all for that price (1700-2000)
Also - T-Quad, not original for a 67, but will work. I believe the 67 had a AVS
