TheTecher
Evan the jeeper.
Hey guys, should my fender tag for my 68 cuda be held in place with rivits or screws?
thanks
thanks
Two screws... look carefully at your fender tag. You will notice a slight crease in one of the corners where the screw holds it on. That one will be painted body color. The other screw will be bare... Reason? Well, the fender tag was secured down on one corner and bent up so it could get paint on and under the tag. Then it was bent down and secured with the unpainted screw. Hope that helps.
