Custom Feed Lines...
VADodgeDart340
Herndon Virginia
I have a Holley Street Eliminator Dual feed carb and I want to do a custom feed line. I don't want to use the "Mr. Gasket" dual feed line with the big knuckle in the front, I want a set of dual lines that end in a nipple so I can have the rubber connector between the fuel pump line and the carb line.
Does anybody out there know of a company that makes this type of thing?
Summit has several on their site.
sounds just like the holley feed line
get a brass inverted flare T and make what you want. most of the dual feed holleys have 3/8" inlets im not sure if you can get 5/16 inlet fittings i used to have a set. you can get the T in 5/16 or 3/8. i bought one from inline tube, but you might be able to get it from an auto parts store.
