360duster
Hi Guys,
next step in my engine build is to measure / order pushrods for it. Can you tell me some good vendors for these?
For the lifter preload: i use hydraulic rollers (factory ones, LA Roller cam block). I want to measure the length of the pushrod when it´s at the cam´s base circle, how much should i add to preload the lifters correctly?
Thanks for Info!
Michael
Thanks for Info!
Michael
