moturbopar
Howards hydraulic flat tappet cam. Lobes are designed to take advantage of mopar .904 lifter.
Cam would be good for a blower or turbo. Will work well N/A also.
Specs are 226 at .050 intake and exhaust. .520 lift with 1.5 ratio rockers. Ground on a 114 lobe seperation with a 110 ic. Cam will have a mild lope and has a powerband of 1800 rpm to 5600 rpm.
New in container. Paid $150 but can use now $100 firm
