chrisskates2004
much apprecitedHello. I was successful at cutting the input shaft on my transmission. Obviously the amount you will need to cut will probably differ some from mine. I’m currently away from home but will return tomorrow and I can measure the amount I removed from my input shaft as the piece is in the drawer of my tool box .
I have put a couple hundred miles on my car since the conversion and all is well.
As others said you will need to get your bellhousing and have it mounted to your engine block before you can ever begin to make any measurements. You can PM me if you like and I will try and provide any info that I can.
Thanks again to everyone who took the time to help me.
Eric.
thanks
