68383GTS
I have a housing that is 1/2 narrower than a stock A body housing.Can I cut axles with a chop saw and tapper the end of the axles with a grinder.I need to cut about a 1/4 - 3/8 of each axle.
are u going to use the stock adjustable axle bearings, if so u need to get the length very accurate
It would be better to use a band saw with coolant so you don't take any of the hardness out of the splines.
