I've got an 8 3/4, truck I think. I want to cut it down to a-body size. When I look inside the stock ends there is a small step down in the ID before you get to the axle tube ID. After the stock ends are cut off, I have the moser ends to weld on. It looks like there will be no step down between the moser ends and the axle tube. Will that be ok like that, or did I miss something? Any help much appreciated.
