Duane
I need to tear down my engine to change some components. The engine has no cylinder ridge from wear, but there is a carbon ridge. I want to re use my piston rings and do not want to damage them when removing the piston/rod assemblies.
What is the easiest way to remove the carbon buildup. Is there a chemical that will dissolve it or something.
Duane
Duane
